Introdução
This guide will show how to replace the camera sensor. The camera sensor collects light to create the image. If your pictures are blurry or low on brightness, the camera sensor may need a replacement.
O que você precisa
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
7 outras pessoas executaram este guia.
2 comentários
not easy to return the ribbon back to its place! it’s easier to throw your gopro after doing this.
Hi, is the sensor for black and silver same? Thank you
