Ir para o conteúdo principal
GoPro Hero3+ Silver Edition Camera Lens Replacement
O que você precisa
  1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: passo 1, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: passo 1, imagem 2 %32
    • Push the tab on the back of the device left to remove the plate covering the battery.
    Pergunte ao FixBot
    Comentar
  2. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 2, imagem 1 %32
    • Use the strip of tape on the battery to remove the battery from the housing.
    Pergunte ao FixBot
    Comentar
  3. GoPro Hero3+ Silver Edition Camera Lens Replacement, Front Panel: passo 3, imagem 1 %32
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    Pergunte ao FixBot
    Comentar
  4. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 4, imagem 1 %32
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    Pergunte ao FixBot
    Comentar
  5. GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: passo 5, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: passo 5, imagem 2 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: passo 5, imagem 3 %32
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    Pergunte ao FixBot
    Comentar
  6. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 6, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 6, imagem 2 %32
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    Pergunte ao FixBot
    Comentar
  7. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 7, imagem 1 %32
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    Pergunte ao FixBot
    Comentar
  8. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 8, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 8, imagem 2 %32
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. GoPro Hero3+ Silver Edition Camera Lens Replacement, microSD/Expansion Port Assembly: passo 9, imagem 1 %32
    • Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
    • A small plate will become separated when the rightmost screw is removed. Just place it to the side.
    Pergunte ao FixBot
    Comentar
  10. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 10, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 10, imagem 2 %32
    • Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
    • The microSD and Accessory Board is now ready for removal.
    Pergunte ao FixBot
    Comentar
  11. GoPro Hero3+ Silver Edition Camera Lens Replacement, Motherboard: passo 11, imagem 1 %32
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
    Pergunte ao FixBot
    Comentar
  12. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 12, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 12, imagem 2 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 12, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
    Pergunte ao FixBot
    Comentar
  13. GoPro Hero3+ Silver Edition Camera Lens Replacement, Camera Lens: passo 13, imagem 1 %32
    • Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
    Pergunte ao FixBot
    Comentar
  14. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 14, imagem 1 %32
    • Carefully remove the lens from the font housing.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
Patrick Cook
Membro desde: 10/01/15
699 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-8, Maness Fall 2015 Membro de Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 40
Ao todo: 2,544
