Ir para o conteúdo principal
GoPro Hero3+ Black Edition Motherboard Replacement
O que você precisa
  1. GoPro Hero3+ Black Edition Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Pull the tab on the back of the device to release the back cover. It should come right off.
    • The device pictured does not include the back cover.
  2. GoPro Hero3+ Black Edition Motherboard Replacement: passo 2, imagem 1 %32
    • Use the battery tab to pull the battery out of the device.
    • Remove the battery from the slot.
  3. GoPro Hero3+ Black Edition Motherboard Replacement, Front Face Plate: passo 4, imagem 1 %32 GoPro Hero3+ Black Edition Motherboard Replacement, Front Face Plate: passo 4, imagem 2 %32
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
  4. GoPro Hero3+ Black Edition Motherboard Replacement, Image Sensor: passo 5, imagem 1 %32 GoPro Hero3+ Black Edition Motherboard Replacement, Image Sensor: passo 5, imagem 2 %32 GoPro Hero3+ Black Edition Motherboard Replacement, Image Sensor: passo 5, imagem 3 %32
    • Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
    • Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
    • Watch out for the ribbon cable connecting the midframe and the motherboard to the GoPro housing. See the next step.
  5. GoPro Hero3+ Black Edition Motherboard Replacement: passo 6, imagem 1 %32 GoPro Hero3+ Black Edition Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
  6. GoPro Hero3+ Black Edition Motherboard Replacement: passo 7, imagem 1 %32
    • Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
    • Disclaimer: Our device is just a teardown unit and no longer has the tape. The markup depicts the location where the tape would be located.
  7. GoPro Hero3+ Black Edition Motherboard Replacement: passo 8, imagem 1 %32
    • Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
    • Disclaimer: The unit used for this guide did not include these screws. Set them aside so you do not mix them up with the previously removed screws.
    Removing this and attempting to reconnect the connector ribbon will be really difficult when re-assembling. If you are simply replacing the LCD screen I recommend skipping to Step 13.
    Devin Roach - Responder
  8. GoPro Hero3+ Black Edition Motherboard Replacement: passo 9, imagem 1 %32 GoPro Hero3+ Black Edition Motherboard Replacement: passo 9, imagem 2 %32
    • Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
    • Remove the image sensor from the motherboard assembly.
  9. GoPro Hero3+ Black Edition Motherboard Replacement, microSD and Accessory Board: passo 10, imagem 1 %32
    • Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
    The threads on the top left screw are different so be sure to take note of which screw is which (although maybe it doesn’t matter that much).
  10. GoPro Hero3+ Black Edition Motherboard Replacement: passo 11, imagem 1 %32 GoPro Hero3+ Black Edition Motherboard Replacement: passo 11, imagem 2 %32
    • Using the spudger tool, pry off the corresponding ribbon cable from the motherboard.
    • The microSD/accessory board is ready to come off.
  11. GoPro Hero3+ Black Edition Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Using your trusty screwdriver, remove the single 3.2mm PH00 screw connecting the motherboard to the midframe.
  12. GoPro Hero3+ Black Edition Motherboard Replacement: passo 13, imagem 1 %32 GoPro Hero3+ Black Edition Motherboard Replacement: passo 13, imagem 2 %32 GoPro Hero3+ Black Edition Motherboard Replacement: passo 13, imagem 3 %32
    • Use the spudger tool to disconnect the front LCD from the motherboard. Gently pull the ribbon cable out.
    • Gently pull the motherboard away from the midframe.
Conclusão
18 outras pessoas executaram este guia.
Chad Carlson
Membro desde: 04/14/15
1.148 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-15, Maness Spring 2015 Membro de Cal Poly, Team 6-15, Maness Spring 2015
CPSU-MANESS-S15S6G15
Membros da 4
Autoria de 13 guias
Um comentário
Hello Chad,
Thanks for the very helpful and detailed guide.
Could you please tell us how you narrowed down the problem to the motherboard and not to other parts? What kind of problems were you having with your GoPro before you repaired it? After you have replaced the motherboard and put the camera back together, did you have to do anything else to make it work like reconfigure the firmware?
Appreciate your help. Thanks!
Handyman Uncle - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 18
Duração total: 7,375
