Ir para o conteúdo principal
GoPro Hero3+ Black Edition LCD Display Replacement
O que você precisa
  1. GoPro Hero3+ Black Edition LCD Display Replacement, Battery: passo 1, imagem 1 %32
    • Pull the tab on the back of the device to release the back cover. It should come right off.
    • The device pictured does not include the back cover.
    Pergunte ao FixBot
  2. GoPro Hero3+ Black Edition LCD Display Replacement: passo 2, imagem 1 %32
    • Use the battery tab to pull the battery out of the device.
    Pergunte ao FixBot
    • Remove the battery from the slot.
    Pergunte ao FixBot
  3. GoPro Hero3+ Black Edition LCD Display Replacement, Front Face Plate: passo 4, imagem 1 %32 GoPro Hero3+ Black Edition LCD Display Replacement, Front Face Plate: passo 4, imagem 2 %32
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
    Pergunte ao FixBot
  4. GoPro Hero3+ Black Edition LCD Display Replacement, Image Sensor: passo 5, imagem 1 %32 GoPro Hero3+ Black Edition LCD Display Replacement, Image Sensor: passo 5, imagem 2 %32 GoPro Hero3+ Black Edition LCD Display Replacement, Image Sensor: passo 5, imagem 3 %32
    • Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
    • Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
    • Watch out for the ribbon cable connecting the midframe and the motherboard to the GoPro housing. See the next step.
    Pergunte ao FixBot
  5. GoPro Hero3+ Black Edition LCD Display Replacement: passo 6, imagem 1 %32 GoPro Hero3+ Black Edition LCD Display Replacement: passo 6, imagem 2 %32
    • Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
    Pergunte ao FixBot
  6. GoPro Hero3+ Black Edition LCD Display Replacement: passo 7, imagem 1 %32
    • Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
    • Disclaimer: Our device is just a teardown unit and no longer has the tape. The markup depicts the location where the tape would be located.
    Pergunte ao FixBot
  7. GoPro Hero3+ Black Edition LCD Display Replacement: passo 8, imagem 1 %32
    • Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
    • Disclaimer: The unit used for this guide did not include these screws. Set them aside so you do not mix them up with the previously removed screws.
    Pergunte ao FixBot
  8. GoPro Hero3+ Black Edition LCD Display Replacement: passo 9, imagem 1 %32 GoPro Hero3+ Black Edition LCD Display Replacement: passo 9, imagem 2 %32
    • Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
    • Remove the image sensor from the motherboard assembly.
    Pergunte ao FixBot
  9. GoPro Hero3+ Black Edition LCD Display Replacement, microSD and Accessory Board: passo 10, imagem 1 %32
    • Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
    Pergunte ao FixBot
  10. GoPro Hero3+ Black Edition LCD Display Replacement: passo 11, imagem 1 %32 GoPro Hero3+ Black Edition LCD Display Replacement: passo 11, imagem 2 %32
    • Using the spudger tool, pry off the corresponding ribbon cable from the motherboard.
    • The microSD/accessory board is ready to come off.
    Pergunte ao FixBot
  11. GoPro Hero3+ Black Edition LCD Display Replacement, Motherboard: passo 12, imagem 1 %32
    • Using your trusty screwdriver, remove the single 3.2mm PH00 screw connecting the motherboard to the midframe.
    Pergunte ao FixBot
  12. GoPro Hero3+ Black Edition LCD Display Replacement: passo 13, imagem 1 %32 GoPro Hero3+ Black Edition LCD Display Replacement: passo 13, imagem 2 %32 GoPro Hero3+ Black Edition LCD Display Replacement: passo 13, imagem 3 %32
    • Use the spudger tool to disconnect the front LCD from the motherboard. Gently pull the ribbon cable out.
    • Gently pull the motherboard away from the midframe.
    Pergunte ao FixBot
  13. GoPro Hero3+ Black Edition LCD Display Replacement, LCD Display: passo 14, imagem 1 %32
    • Now that you have removed the plastic midframe from the motherboard, nothing is standing in the way of the LCD!
    • Carefully remove the ribbon cable from the midframe. It is attached with glue, so a spudger tool (or a heat gun if it's stubborn) will be needed.
    Pergunte ao FixBot
Conclusão
5 outras pessoas executaram este guia.
Kyle Rooney
Membro desde: 04/14/15
502 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-15, Maness Spring 2015 Membro de Cal Poly, Team 6-15, Maness Spring 2015
CPSU-MANESS-S15S6G15
4 Membros
Autoria de 13 guias
7Comentários do guia
Where did you buy the replacement from?
Colin Murphy - Responder Compartilhar
I got my one from AliExpress (https://www.aliexpress.com/store/product...).
John Mills - Responder Compartilhar
Merci beaucoup, trés utile pour les pilotes de drones fpv!
Thanks a lot, very helpfull for drone racers!
https://www.banggood.com/Front-LCD-Displ...
PoLy “PoLy” Vincent - Responder Compartilhar
Dose it work for the silver édition as well ?
mojooe - Responder Compartilhar
Thanks for this! I will just add that there is no need to take off the image sensor and the microSD board. You can simply skip from Step 6 to Step 13 without removing the motherboard. I wasted a lot of effort and almost broke my GoPro doing Steps 6-13.
Devin Roach - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 81
Ao todo: 3,906
