Ir para o conteúdo principal
GoPro Hero Motherboard Replacement
O que você precisa
  1. GoPro Hero Motherboard Replacement, Casing: passo 1, imagem 1 %32
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Motherboard Replacement: passo 2, imagem 1 %32
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Motherboard Replacement: passo 3, imagem 1 %32
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Motherboard Replacement: passo 4, imagem 1 %32
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Motherboard Replacement: passo 5, imagem 1 %32
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Motherboard Replacement: passo 6, imagem 1 %32
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 GoPro Hero Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Motherboard Replacement: passo 8, imagem 1 %32 GoPro Hero Motherboard Replacement: passo 8, imagem 2 %32
    • Separate the white plastic piece from the motherboard.
Conclusão
4 outras pessoas executaram este guia.
Zoe Tuggle
Membro desde: 04/01/15
179 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
Membros da 4
Autoria de 18 guias
2 comentários
So after doing all theses steps did it resolve the problem
Anita - Responder
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 41
Duração total: 10,095
