Ir para o conteúdo principal
GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement
O que você precisa
  1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Casing: passo 1, imagem 1 %32
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 2, imagem 1 %32
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 3, imagem 1 %32
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 4, imagem 1 %32
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 5, imagem 1 %32
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 6, imagem 1 %32
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: passo 7, imagem 1 %32 GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: passo 7, imagem 2 %32
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 8, imagem 1 %32
    • Remove the two screws located on each side of the board with a Phillips screwdriver.
    • The screws go through an L metal bracket that will come off with the screws.
  9. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 9, imagem 1 %32
    • Separate the daughter board from the white plastic piece.
Conclusão
5 outras pessoas executaram este guia.
River Drake
Membro desde: 04/02/15
1.047 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Membros
Autoria de 18 guias
4Comentários do guia
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Lukas Blohm - Responder
bravo! è scritto molto bene ed è stato utile. ma dove trovo il ricambio? non ci riesco!!!
michele - Responder
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - Responder
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 5,161
