Ir para o conteúdo principal
GoPro Hero Lens Replacement
O que você precisa
  1. GoPro Hero Lens Replacement, Casing: passo 1, imagem 1 %32
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Lens Replacement: passo 2, imagem 1 %32
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Lens Replacement: passo 3, imagem 1 %32
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Lens Replacement: passo 4, imagem 1 %32
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Lens Replacement: passo 5, imagem 1 %32
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Lens Replacement: passo 6, imagem 1 %32
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Lens Replacement, Lens: passo 7, imagem 1 %32
    • Remove the four screws from the lens.
    • These screws are smaller than the ones removed from the white plastic piece.
  8. GoPro Hero Lens Replacement: passo 8, imagem 1 %32
    • Remove the lens from the case.
    Spot on... Contacted Gopro preciously & they say it's not a replaceable item!.. how wrong are they!
    Thank you.
    Gary Traviss - Responder
Conclusão
To reassemble your device, follow the instructions in reverse order.
3 outras pessoas executaram este guia.
River Drake
Membro desde: 04/02/15
1.035 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
Membros da 4
Autoria de 18 guias
Um comentário
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 106
Duração total: 12,467
