Ir para o conteúdo principal
GoPro Hero 3 Silver Rear Housing Replacement
O que você precisa
  1. GoPro Hero 3 Silver Rear Housing Replacement, Battery: passo 1, imagem 1 %32 GoPro Hero 3 Silver Rear Housing Replacement, Battery: passo 1, imagem 2 %32
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Rear Housing Replacement: passo 2, imagem 1 %32
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: passo 3, imagem 1 %32 GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: passo 3, imagem 2 %32
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Rear Housing Replacement: passo 4, imagem 1 %32 GoPro Hero 3 Silver Rear Housing Replacement: passo 4, imagem 2 %32
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Rear Housing Replacement: passo 5, imagem 1 %32 GoPro Hero 3 Silver Rear Housing Replacement: passo 5, imagem 2 %32
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Rear Housing Replacement: passo 6, imagem 1 %32 GoPro Hero 3 Silver Rear Housing Replacement: passo 6, imagem 2 %32
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Rear Housing Replacement: passo 7, imagem 1 %32
    • In order to replace the buttons. The entire housing has to be replaced.
Conclusão
Uma outra pessoa concluiu este guia.
Brian Alvarez
Membro desde: 04/02/15
1.439 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 24-7, Lancaster Spring 2015 Membro de Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
Membros da 3
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 2,316
