Ir para o conteúdo principal
GoPro HD Hero2 LCD Replacement
O que você precisa
  1. GoPro HD Hero2 LCD Replacement, Back Cover: passo 1, imagem 1 %32 GoPro HD Hero2 LCD Replacement, Back Cover: passo 1, imagem 2 %32
    • Place your thumb on the indentation in the back case on the side of the GoPro.
    • Gently press down with your thumb and lift the back cover away from the case to remove it.
  2. GoPro HD Hero2 LCD Replacement, Battery: passo 2, imagem 1 %32 GoPro HD Hero2 LCD Replacement, Battery: passo 2, imagem 2 %32
    • Slide a plastic opening tool between the battery and the rear case.
    • Gently pry the battery up and out of the rear case.
  3. GoPro HD Hero2 LCD Replacement: passo 3, imagem 1 %32
    • Remove the battery from the case.
  4. GoPro HD Hero2 LCD Replacement, Rear Case: passo 4, imagem 1 %32
    • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Two 5.5 mm coarse thread screws.
    • Two 4.4 mm fine thread screws.
  5. GoPro HD Hero2 LCD Replacement: passo 5, imagem 1 %32 GoPro HD Hero2 LCD Replacement: passo 5, imagem 2 %32
    • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
    • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
  6. GoPro HD Hero2 LCD Replacement: passo 6, imagem 1 %32 GoPro HD Hero2 LCD Replacement: passo 6, imagem 2 %32
    • Grasp the rear case and lift it off of the front case.
    • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
  7. GoPro HD Hero2 LCD Replacement: passo 7, imagem 1 %32 GoPro HD Hero2 LCD Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
    • Be careful that you are prying on the locking tab, and not the connector itself.
    • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
  8. GoPro HD Hero2 LCD Replacement: passo 8, imagem 1 %32 GoPro HD Hero2 LCD Replacement: passo 8, imagem 2 %32 GoPro HD Hero2 LCD Replacement: passo 8, imagem 3 %32
    • Lift the speaker out of the rear case with the tip of a spudger.
    • Remove the rear case.
  9. GoPro HD Hero2 LCD Replacement, Motherboard Assembly: passo 9, imagem 1 %32
    • Remove the three screws securing the motherboard assembly to the front case:
    • Two 10.8 mm Phillips #00 screws.
    • One 4.8 mm Phillips #00 screw.
  10. GoPro HD Hero2 LCD Replacement: passo 10, imagem 1 %32 GoPro HD Hero2 LCD Replacement: passo 10, imagem 2 %32
    • Gently grab the edges of the motherboard assembly and lift it out of the front case.
  11. GoPro HD Hero2 LCD Replacement, LCD: passo 11, imagem 1 %32 GoPro HD Hero2 LCD Replacement, LCD: passo 11, imagem 2 %32
    • Turn the motherboard assembly over to the side with the LCD and the camera lens.
    • Gently wedge a plastic opening tool underneath the foam padding on top of the LCD ribbon cable.
    • Pry the foam padding up until the LCD ribbon cable can be lifted off the surface of the motherboard.
    • Do not try to remove the LCD yet, as its ribbon cable is still connected to the motherboard via a ZIF connector.
  12. GoPro HD Hero2 LCD Replacement: passo 12, imagem 1 %32 GoPro HD Hero2 LCD Replacement: passo 12, imagem 2 %32
    • Use the tip of a spudger to release the two outer tabs of the LCD ribbon cable ZIF connector.
    • Alternate pressing on both tabs until the connector is completely unfastened.
  13. GoPro HD Hero2 LCD Replacement: passo 13, imagem 1 %32
    • Once its ribbon cable is free, remove the LCD from the motherboard assembly.
Conclusão
5 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
155.760 Reputação
Autoria de 127 guias
13Comentários do guia
Where do you purchase the replacement lcd?
Max Kauker - Responder Compartilhar
hero2 lcd led replacement part available here
http://ragecams.com/shop/gopro-hero2-lcd...
dennis - Compartilhar
I'm also looking for an LCD replacekit. Unfortionally I broken the front LCD of a GoPro Here 3 cam.
Where can I get one?
arno - Responder Compartilhar
Im also in need of a LCD for my GoPro Here 3+
is there anyone who can help me and the other 2 guys ?!!
aria - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 15,683
