Introdução
Replace your dying GoPro battery with a fresh one. If you're ready to jump off a mountain, your battery should be too!
  1. Place your thumb on the indentation in the back case on the side of the GoPro.
    • Place your thumb on the indentation in the back case on the side of the GoPro.
    • Gently press down with your thumb and lift the back cover away from the case to remove it.
  2. Slide a plastic opening tool between the battery and the rear case.
    • Slide a plastic opening tool between the battery and the rear case.
    • Gently pry the battery up and out of the rear case.
    • Remove the battery from the case.
Conclusão
2 outras pessoas concluíram este guia.
David Hodson
132.908 reputação
127 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Todo: 12,834
