Introdução
If your cable for your Glorious Model O or O- (Model GOM-GWHITE) is having disconnecting issues or the braided cord has a rip, this guide can show you how to replace your cable.
The mouse cord transmits data between your mouse and computer. If this cord is damaged the mouse will be unresponsive, randomly disconnect, and have sudden movement. Before using this guide, make sure you try connecting your mouse to other USB ports to see if its not a USB port issue. A good practice is also unplugging your mouse before removing your cable.
For external resources and software, Glorious has software and user manuals on their website Software & Manuals.
O que você precisa
Take your blow dryer and turn on the heat setting. Aim the heat at the bottom two mouse skates.
Peel it off using your hands or nails when the adhesive is warm.
