Ir para o conteúdo principal
Gigabyte RTX 3060 GPU Fan Replacement
O que você precisa
  1. Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: passo 1, imagem 1 %32 Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: passo 1, imagem 2 %32 Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: passo 1, imagem 3 %32
    • Remove the four springs screws attached to the thermal plate on the GPU using a Phillips #00 screwdriver.
    • Remove the two screws from the right side using a Phillips #00 screwdriver.
    • Remove the two screws from the left side using a Phillips #00 screwdriver.
  2. Gigabyte RTX 3060 GPU Fan Replacement: passo 2, imagem 1 %32 Gigabyte RTX 3060 GPU Fan Replacement: passo 2, imagem 2 %32 Gigabyte RTX 3060 GPU Fan Replacement: passo 2, imagem 3 %32
    • Lift the backplate off after the screws are removed.
    • You will notice both sides of the card have a cable holding the cover and the main GPU board.
    • Carefully remove the connector at the top of the GPU (the side with GEFORCE RTX like on the picture) connecting the GPU board and the fan cover.
  3. Gigabyte RTX 3060 GPU Fan Replacement: passo 3, imagem 1 %32 Gigabyte RTX 3060 GPU Fan Replacement: passo 3, imagem 2 %32
    • Flip over the GPU cover.
    • Remove the four screws using a Phillips #00 screwdriver.
  4. Gigabyte RTX 3060 GPU Fan Replacement: passo 4, imagem 1 %32 Gigabyte RTX 3060 GPU Fan Replacement: passo 4, imagem 2 %32
    • Set the thermal system to the side.
    • Flip over the GPU cover with the fans and find the fan that needs to be replaced.
    • There are three screws underneath the fan blades. Look at the second picture as a reference for one of the screws. Remove all three using a Phillips #00 screwdriver.
  5. Gigabyte RTX 3060 GPU Fan Replacement: passo 5, imagem 1 %32 Gigabyte RTX 3060 GPU Fan Replacement: passo 5, imagem 2 %32
    • Remove the connector associated with the fan.
    • Pull the fan out with its connector cable intact.
  6. Gigabyte RTX 3060 GPU Fan Replacement: passo 6, imagem 1 %32
    • Grab your replacement fan for the Gigabyte RTX 3060.
    • The repair can be completed with the replacement fan by reversing the steps previously shown.
Conclusão
sanskar1016
Membro desde: 10/25/23
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 56
Últimos 30 dias: 231
Duração total: 1,422
