Introdução
Follow the steps below to thoroughly clean your 2070 Super video card and replace thermal paste and thermal pads.
O que você precisa
Using the #1 Philips screwdriver, remove the two screws below the fan shroud
Turn the video card to face the display ports
Remove the four screws using a #0 Philips screwdriver
Using a #0 Philips screwdriver, remove the two screws holding the fan shroud to the heat sink, then flip the card over and remove the identicaltwo screws from the other side of the card
Disconnect the two fan connectors from the video card
Separate the fan shroud from the video card
Flip the card over so the back plate is facing up
Using a #0 Philips screwdriver, remove the four screws with springs from the back plate
Using a #0 Philips screwdriver, remove the three remaining screws from the back plate
Flip the card back over and carefully remove the heat sink from the card
Using a #0 Philips screwdriver, remove the three screws from the front of the card
Carefully remove the back plate from the card
Using 90% or higher isopropyl alcohol and cotton swabs, carefully remove all old thermal paste from the heat sink and CPU
Be sure to completely remove any remnants of the old thermal paste
Using a high quality thermal paste, such as Thermalright TF thermal paste, carefully apply a small amount to the video card
Use a thin spreader, or credit card-like tool, spread the thermal paste evenly over the card, ensuring no excess paste leaks over the edge
Heating the thermal paste in warm water may help it spread more evenly
Remove the old thermal pads and clean the VRAM chips with 90% isopropyl alcohol
Using the 0.5 mm thermal pad, place one strip, measured at 6 cm x 1.5 cm along the top VRAM
Using the 0.5 mm thermal pad, place two strips, measured at 3 cm x 1.5 cm along the VRAM on either side of the CPU
Remove the old thermal pads and clean the heat sink with 90% isopropyl alcohol
Using the 1.0 mm thermal pad, place three strips, measured at 9 cm x 1.3 cm, along the heat sink as outlined in red
Using the 2.0 mm thermal pad, place one strip, measured at 9 cm x 1.3 cm, along the heat sink as outlined in green
Remove the old thermal pads and clean the back plate with 90% isopropyl alcohol
Using the 2.5 mm thermal pad, place one strip, measured at 5 cm x 1 cm on the back plate as outlined in red
Using the 2.5 mm thermal pad, place one strip, measured at 3.5 cm x 1.5 cm on the back plate as outlined in green
Using the 2.5 mm thermal pad, place one strip, measured at 6.5 cm x 1.5 cm on the back plate as outlined in blue
Follow all steps in reverse order to reassemble the video card once cleaned and thermal paste and all thermal pads are replaced
4 comentários
Thank you so much. It was exactly what I was looking for.
steps 1 and 2 (fan shroud/display port shield) are unnecessary. The entire fan + heatsink assembly comes off in one piece and the DP shield stays attached to the board. Also on step 8, all of the pads are 1mm. The green one was not 2mm on mine. (measured with caliper, they are all identical)
On step 8, 9x1.3cm wasn't too wide? It looks more like 9x0.8cm.
Albert -
