Ir para o conteúdo principal
Giant Talon 29er Chainring Replacement
O que você precisa
  1. Giant Talon 29er Chainring Replacement, Chainring: passo 1, imagem 1 %32 Giant Talon 29er Chainring Replacement, Chainring: passo 1, imagem 2 %32 Giant Talon 29er Chainring Replacement, Chainring: passo 1, imagem 3 %32
    • Push the chain tensioner towards the front of the bicycle to release the tension on the chain.
    • Unroute the chain from the chainrings.
  2. Giant Talon 29er Chainring Replacement: passo 2, imagem 1 %32
    • Remove the 8 mm Hex screw from the crank arm.
  3. Giant Talon 29er Chainring Replacement: passo 3, imagem 1 %32
    • Remove the crank arm and chainrings by pulling the crank arm away from the bicycle frame.
  4. Giant Talon 29er Chainring Replacement: passo 4, imagem 1 %32
    • Remove the four 5 mm Hex screws that mount the crank arm to the chainrings.
  5. Giant Talon 29er Chainring Replacement: passo 5, imagem 1 %32 Giant Talon 29er Chainring Replacement: passo 5, imagem 2 %32 Giant Talon 29er Chainring Replacement: passo 5, imagem 3 %32
    • Rotate the largest chainring 45 degrees in either direction.
    • Remove the crank arm from the chainrings.
Conclusão
Reassemble your bicycle with the new chainrings by following these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Ben Frisbie
Membro desde: 03/22/16
209 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 15
Duração total: 3,420
