Ir para o conteúdo principal
Giant Reign 2 Headset Replacement
O que você precisa
  1. Giant Reign 2 Headset Replacement, Hex Screws: passo 1, imagem 1 %32
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Headset Replacement, Axle Screw: passo 2, imagem 1 %32 Giant Reign 2 Headset Replacement, Axle Screw: passo 2, imagem 2 %32
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Headset Replacement: passo 3, imagem 1 %32
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Headset Replacement, Front Wheel: passo 4, imagem 1 %32
    • Pull the wheel from the fork.
  5. Giant Reign 2 Headset Replacement, Headset: passo 5, imagem 1 %32 Giant Reign 2 Headset Replacement, Headset: passo 5, imagem 2 %32
    • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
    • If necessary use wire cutters to release zip ties attaching cables to the forks.
  6. Giant Reign 2 Headset Replacement: passo 6, imagem 1 %32 Giant Reign 2 Headset Replacement: passo 6, imagem 2 %32 Giant Reign 2 Headset Replacement: passo 6, imagem 3 %32
    • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
    • Using the 4mm Allen wrench, loosen the side screw on both sides.
    • Lift off the handlebar.
    • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
  7. Giant Reign 2 Headset Replacement: passo 7, imagem 1 %32 Giant Reign 2 Headset Replacement: passo 7, imagem 2 %32 Giant Reign 2 Headset Replacement: passo 7, imagem 3 %32
    • Slide off the spacers.
    • Lift off the seal.
  8. Giant Reign 2 Headset Replacement: passo 8, imagem 1 %32
    • Slide the fork out of the casing.
  9. Giant Reign 2 Headset Replacement: passo 9, imagem 1 %32
    • Using your fingers, pry the bearings from the top and bottom of the headset.
  10. Giant Reign 2 Headset Replacement: passo 10, imagem 1 %32
    • Apply WD-40 to both ends of the headset and bearings.
    • Dry headset and bearings with paper towels.
    • Repeat as necessary until clean.
  11. Giant Reign 2 Headset Replacement: passo 11, imagem 1 %32 Giant Reign 2 Headset Replacement: passo 11, imagem 2 %32
    • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
    • Insert the bearings into the headset with the beveled side facing into the headset.
Conclusão
Uma outra pessoa concluiu este guia.
Sterling Grande
Membro desde: 10/08/12
148 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-14, Amido Fall 2012 Membro de Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 4,080
