Ir para o conteúdo principal
Giant Reign 2 Front Wheel Replacement
O que você precisa
  1. Giant Reign 2 Front Wheel Replacement, Hex Screws: passo 1, imagem 1 %32
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Front Wheel Replacement, Axle Screw: passo 2, imagem 1 %32 Giant Reign 2 Front Wheel Replacement, Axle Screw: passo 2, imagem 2 %32
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Front Wheel Replacement: passo 3, imagem 1 %32
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Front Wheel Replacement, Front Wheel: passo 4, imagem 1 %32
    • Pull the wheel from the fork.
Conclusão
Andrew Krasts
Membro desde: 10/05/12
302 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-14, Amido Fall 2012 Membro de Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 167
Duração total: 11,501
