Ir para o conteúdo principal
Getting randomly stuck at 100% input
O que você precisa
  1. Getting randomly stuck at 100% input, Perform Maintenance: passo 1, imagem 1 %32
    • You can find a guide on how to perform that here.
  2. Getting randomly stuck at 100% input, Remove your carpet: passo 2, imagem 1 %32
    • If you have a carpet underneath your setup, remove it.
    • If the carpet is built into the floor, buy an anti-static floor mat to fit underneath your setup.
    • Create a path from your rig or pedals to Earth, so that static electricity would dissipate through it.
    • Not all homes have grounding built-in. You may need to get creative or create grounding yourself.
    • Understanding the ESD is important. Read more about it here, here and here.
Conclusão
Eliminating possibility of Electro-Static Discharge will prevent your pedal getting randomly stuck at 100% or 50% input.
Formica Fusca
Membro desde: 08/01/24
2.595 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 198
