Ir para o conteúdo principal
George Foreman Wire Repair
O que você precisa
  1. George Foreman Wire Repair, George Foreman Wire Repair: passo 1, imagem 1 %32
    • Make sure the appliance is unplugged and cooled off before beginning the repair.
    • If the appliance is still on, this could lead to safety hazards such as burning of the hand or electrocution.
    • Lights will appear lit if the appliance is still on so make sure the lights are not illuminated.
  2. George Foreman Wire Repair: passo 2, imagem 1 %32
    • Open the appliance by lifting the top plate away from you.
  3. George Foreman Wire Repair: passo 3, imagem 1 %32 George Foreman Wire Repair: passo 3, imagem 2 %32
    • Remove the plates by pushing down on the black knobs on either side of the plates, top and bottom.
    • After, pick up and lift the plates off of the appliance.
  4. George Foreman Wire Repair: passo 4, imagem 1 %32 George Foreman Wire Repair: passo 4, imagem 2 %32 George Foreman Wire Repair: passo 4, imagem 3 %32
    • Underneath where the plates sit you will see a coil and 12 screws holding the base plate in place.
    • Remove the 12 Phillips head screws on the bottom plate with a #1 Phillips head screw driver.
  5. George Foreman Wire Repair: passo 5, imagem 1 %32
    • After unscrewing the screws, lift off the base plate.
    • This is where you will see the wires.
  6. George Foreman Wire Repair: passo 6, imagem 1 %32 George Foreman Wire Repair: passo 6, imagem 2 %32
    • Re-establish the disconnected or loose wires by pushing them back into the point of connection.
    • Push the wires into the connection center on the bottom of the plate until you can't anymore. This is how you know they will not come loose again.
    • Make sure to keep the wires separated so they do not touch and become tangled to avoid sparks and electrocution.
Conclusão
Uma outra pessoa concluiu este guia.
Ali Sealby
Membro desde: 07/02/18
163 Reputação
Autoria de 1 guia
1Comentário do guia
Unable to repair the split cord on my George Foreman small health fit grill model 25800 as the plates are screwed on. Please advise.
Ann Holdsworth - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 44
Ao todo: 3,090
