Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If you are experiencing an unresponsive TV remote it could be due to a malfunctioning Infrared (IR) LED. The IR LED emits a signal recepted by the TV which allows the user to adjust and control the features of their TV. In this guide you will find how to repair your remote by replacing the IR LED.
Be sure to remove the battery prior to beginning the repair.
O que você precisa
Starting to the side of the front LED, pry up the top of the remote.
Remove the top of the remote to expose the circuit board.
