Introdução
Use this guide to remove or replace the front assembly on the General Wire Drain Cleaner RSVD 2014.
O que você precisa
Use a flathead screwdriver to loosen the three screws around the edge of the front assembly.
Pull the front assembly off of the drain cleaner and slide it over the cable to remove it.
