Ir para o conteúdo principal
General Electric Telephone 2-9710A Base Speaker Replacement
O que você precisa
  1. General Electric Telephone 2-9710A Base Speaker Replacement, Phone Cord: passo 1, imagem 1 %32 General Electric Telephone 2-9710A Base Speaker Replacement, Phone Cord: passo 1, imagem 2 %32
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. General Electric Telephone 2-9710A Base Speaker Replacement: passo 2, imagem 1 %32 General Electric Telephone 2-9710A Base Speaker Replacement: passo 2, imagem 2 %32 General Electric Telephone 2-9710A Base Speaker Replacement: passo 2, imagem 3 %32
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. General Electric Telephone 2-9710A Base Speaker Replacement, 9V Base Battery: passo 3, imagem 1 %32 General Electric Telephone 2-9710A Base Speaker Replacement, 9V Base Battery: passo 3, imagem 2 %32
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. General Electric Telephone 2-9710A Base Speaker Replacement, Remove Volume Dial: passo 4, imagem 1 %32 General Electric Telephone 2-9710A Base Speaker Replacement, Remove Volume Dial: passo 4, imagem 2 %32
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. General Electric Telephone 2-9710A Base Speaker Replacement, Remove Screws on the Back: passo 5, imagem 1 %32
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. General Electric Telephone 2-9710A Base Speaker Replacement, Pry the Back Off: passo 6, imagem 1 %32 General Electric Telephone 2-9710A Base Speaker Replacement, Pry the Back Off: passo 6, imagem 2 %32
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
  7. General Electric Telephone 2-9710A Base Speaker Replacement, Base Speaker: passo 7, imagem 1 %32 General Electric Telephone 2-9710A Base Speaker Replacement, Base Speaker: passo 7, imagem 2 %32 General Electric Telephone 2-9710A Base Speaker Replacement, Base Speaker: passo 7, imagem 3 %32
    • Slightly pull out speaker.
    • Cut wire as close as speaker as possible with wire cutters.
    • Remove speaker.
  8. General Electric Telephone 2-9710A Base Speaker Replacement: passo 8, imagem 1 %32 General Electric Telephone 2-9710A Base Speaker Replacement: passo 8, imagem 2 %32 General Electric Telephone 2-9710A Base Speaker Replacement: passo 8, imagem 3 %32
    • Strip the wire half an inch using wire strippers for a 24 gauge wire.
  9. General Electric Telephone 2-9710A Base Speaker Replacement: passo 9, imagem 1 %32
    • Solder on the new speaker.
    • Please visit How to Solder to learn more about soldering.
Conclusão
Equipe
Cal Poly, Team 16-59, Forte Fall 2012 Membro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,404
