Introdução
This guide will demonstrate how to remove the LCD screen and replace it with a new one.
O que você precisa
Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
With the back casing that you just separated from the camera, use your finger to push the LCD screen from the frame.
Uma outra pessoa concluiu este guia.
