Ir para o conteúdo principal
General Electric Bagel Switch 4-Slice Power Supply Replacement
O que você precisa
  1. General Electric Bagel Switch 4-Slice Power Supply Replacement, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: passo 1, imagem 1 %32
    • Unplug the toaster from the electrical outlet.
  2. General Electric Bagel Switch 4-Slice Power Supply Replacement: passo 2, imagem 1 %32 General Electric Bagel Switch 4-Slice Power Supply Replacement: passo 2, imagem 2 %32
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. General Electric Bagel Switch 4-Slice Power Supply Replacement: passo 3, imagem 1 %32
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
  4. General Electric Bagel Switch 4-Slice Power Supply Replacement, Power Supply: passo 4, imagem 1 %32
    • Flip the toaster over so that the bottom plate is facing up.
  5. General Electric Bagel Switch 4-Slice Power Supply Replacement: passo 5, imagem 1 %32 General Electric Bagel Switch 4-Slice Power Supply Replacement: passo 5, imagem 2 %32
    • Remove the four screws from the bottom of the toaster.
    • Carefully separate the bottom plate from the metal components inside the toaster.
  6. General Electric Bagel Switch 4-Slice Power Supply Replacement: passo 7, imagem 1 %32
    • Using wire cutters, cut the power supply cable close to the base of the toaster, leave about 2 inches of wire.
  7. General Electric Bagel Switch 4-Slice Power Supply Replacement: passo 8, imagem 1 %32
    • Pull the power supply cord through the bottom plate of the toaster.
    • Insert the end of the new power supply cable through the hole in the bottom plate.
  8. General Electric Bagel Switch 4-Slice Power Supply Replacement: passo 10, imagem 1 %32
    • Strip about an inch of the wire insulation (casing) off the ends of both the new power supply cable, and the old power supply cable that is still attached to the toaster.
    • Splice the stripped ends of wire together using a wire cap.
Conclusão
Ron Gajdos
Membro desde: 10/16/13
307 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 Membro de UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 518
