Ir para o conteúdo principal
General Electric Bagel Switch 4 Slice Bottom Plate Replacement
O que você precisa
  1. General Electric Bagel Switch 4 Slice Bottom Plate Replacement, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: passo 1, imagem 1 %32
    • Unplug the toaster from the electrical outlet.
  2. General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 2, imagem 1 %32 General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 2, imagem 2 %32
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 3, imagem 1 %32
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
  4. General Electric Bagel Switch 4 Slice Bottom Plate Replacement, Bottom Plate: passo 4, imagem 1 %32
    • Turn the toaster upside down. Bagel slots are not showing.
  5. General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 5, imagem 1 %32
    • Locate the screws that are holding the bottom plate onto the toaster. There are four (4) screws. (1 screw in each corner.)
  6. General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 6, imagem 1 %32
    • With a Phillips head screwdriver, remove all (4) of the screws.
  7. General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 7, imagem 1 %32
    • You will notice that the cord for the plug is also attached to the bottom. You will need to remove it from the bottom plate.
    • The bottom plate is now free to be removed.
  8. General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 8, imagem 1 %32
    • Now that the bottom plate is completely off, you can put the new bottom plate on.
    • You may damage parts if you do this step incorrectly.
    • Start by running the cord around the grooves of the bottom plate. Match up the cord with the same path that you removed the cord from the bottom plate. Make sure it lines up correctly.
  9. General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 9, imagem 1 %32
    • Now the bottom plate is in place. Put the (4) four screws that hold it on, back into where you removed them from. Use the screwdriver to do this.
    • Once these (4) screws have been tightened, in the correct holes, you have finished replacing the bottom plate.
  10. General Electric Bagel Switch 4 Slice Bottom Plate Replacement: passo 10, imagem 1 %32
    • Turn the toaster right side up. Replacement is now complete.
Conclusão
Jacqueline Tran
Membro desde: 10/29/13
101 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 Membro de UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 637
