Ir para o conteúdo principal
General Disassembly LG VX8560
O que você precisa
  1. General Disassembly LG VX8560, General Disassembly LG VX8560: passo 1, imagem 1 %32
    • Flip phone over so its backside is facing up.
  2. General Disassembly LG VX8560: passo 2, imagem 1 %32
    • Push from indentation and slide battery cover away from phone to remove battery cover.
  3. General Disassembly LG VX8560: passo 3, imagem 1 %32
    • Take out the battery once cover is off by gently prying with your fingers.
  4. General Disassembly LG VX8560: passo 4, imagem 1 %32
    • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  5. General Disassembly LG VX8560: passo 5, imagem 1 %32 General Disassembly LG VX8560: passo 5, imagem 2 %32
    • Using your plastic pry tool, insert the tool between the phone’s keypad cover and back cover and gently pry apart.
  6. General Disassembly LG VX8560: passo 6, imagem 1 %32
    • Once the covers have been separated the motherboard will be visible. Do not separate the two covers completely. The covers will be held together by a screw on the axis of the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Jack Foley
Membro desde: 04/25/13
37 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 13-62, Johann Spring 2013 Membro de Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
Membros da 4
Autoria de 12 guias
Um comentário
Concerning a LG Chocolate 3 still activated and perfectly working but with a damaged frame. Can you take the activated internal parts out of a damaged frame phone and install in a like new condition identical phone frame ?
Zamora - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 410
