Ir para o conteúdo principal
GeeksPhone Keon Back Plate Replacement
O que você precisa
  1. GeeksPhone Keon Back Plate Replacement, Battery: passo 1, imagem 1 %32 GeeksPhone Keon Back Plate Replacement, Battery: passo 1, imagem 2 %32
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon Back Plate Replacement: passo 2, imagem 1 %32
    • Lift the cover away from the phone.
  3. GeeksPhone Keon Back Plate Replacement: passo 3, imagem 1 %32
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon Back Plate Replacement, Back Plate: passo 4, imagem 1 %32 GeeksPhone Keon Back Plate Replacement, Back Plate: passo 4, imagem 2 %32
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon Back Plate Replacement: passo 5, imagem 1 %32 GeeksPhone Keon Back Plate Replacement: passo 5, imagem 2 %32
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon Back Plate Replacement: passo 6, imagem 1 %32
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon Back Plate Replacement: passo 7, imagem 1 %32 GeeksPhone Keon Back Plate Replacement: passo 7, imagem 2 %32 GeeksPhone Keon Back Plate Replacement: passo 7, imagem 3 %32
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon Back Plate Replacement: passo 8, imagem 1 %32 GeeksPhone Keon Back Plate Replacement: passo 8, imagem 2 %32
    • Lift the backplate away from the device.
Conclusão
Equipe
USF Tampa, Team 3-5, Eyestone Fall 2015 Membro de USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 138
