Ir para o conteúdo principal
GeeksPhone Keon Camera Replacement
O que você precisa
  1. GeeksPhone Keon  Camera Replacement, Battery: passo 1, imagem 1 %32 GeeksPhone Keon  Camera Replacement, Battery: passo 1, imagem 2 %32
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    Pergunte ao FixBot
    Comentar
  2. GeeksPhone Keon  Camera Replacement: passo 2, imagem 1 %32
    • Lift the cover away from the phone.
    Pergunte ao FixBot
    Comentar
  3. GeeksPhone Keon  Camera Replacement: passo 3, imagem 1 %32
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    Pergunte ao FixBot
    Comentar
  4. GeeksPhone Keon  Camera Replacement, Back Plate: passo 4, imagem 1 %32 GeeksPhone Keon  Camera Replacement, Back Plate: passo 4, imagem 2 %32
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
    Pergunte ao FixBot
    Comentar
  5. GeeksPhone Keon  Camera Replacement: passo 5, imagem 1 %32 GeeksPhone Keon  Camera Replacement: passo 5, imagem 2 %32
    • Gently remove the small orange plate by pulling it down.
    Pergunte ao FixBot
    Comentar
  6. GeeksPhone Keon  Camera Replacement: passo 6, imagem 1 %32
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
    Pergunte ao FixBot
    Comentar
  7. GeeksPhone Keon  Camera Replacement: passo 7, imagem 1 %32 GeeksPhone Keon  Camera Replacement: passo 7, imagem 2 %32 GeeksPhone Keon  Camera Replacement: passo 7, imagem 3 %32
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
    Pergunte ao FixBot
    Comentar
  8. GeeksPhone Keon  Camera Replacement: passo 8, imagem 1 %32 GeeksPhone Keon  Camera Replacement: passo 8, imagem 2 %32
    • Lift the backplate away from the device.
    Pergunte ao FixBot
    Comentar
  9. GeeksPhone Keon  Camera Replacement, Camera: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Lift the retaining flap on camera's ZIF connector.
    • Pull the ribbon cable away with tweezers.
    Pergunte ao FixBot
    Comentar
  10. GeeksPhone Keon  Camera Replacement: passo 10, imagem 1 %32 GeeksPhone Keon  Camera Replacement: passo 10, imagem 2 %32 GeeksPhone Keon  Camera Replacement: passo 10, imagem 3 %32
    • Carefully wiggle the camera away from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order; but remember, the new camera must be glued back in place where the old one was removed.
Bryan Bittner
Membro desde: 08/26/15
167 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 3-5, Eyestone Fall 2015 Membro de USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Ao todo: 346
