Introdução
After calling your service provider, if you are having bad cellular reception or other service issues, use this guide to replace the antenna.
O que você precisa
Insert the plastic opening tool into the seam between the front of the device and the rear cover.
Slide the plastic opening tool from the bottom of the phone to the top.
Use the plastic opening tool to free all the clips attached to the phone.
Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
Unfasten the plastic clamps attached to the antenna.
