Ir para o conteúdo principal
Gateway W350I Heatsink Fan Replacement
O que você precisa
  1. Gateway W350I Heatsink Fan Replacement, Battery Access: passo 1, imagem 1 %32
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: passo 2, imagem 1 %32 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: passo 2, imagem 2 %32 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: passo 2, imagem 3 %32
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: passo 3, imagem 1 %32 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: passo 3, imagem 2 %32 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: passo 3, imagem 3 %32
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
  4. Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: passo 4, imagem 1 %32 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: passo 4, imagem 2 %32 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: passo 4, imagem 3 %32
    • Remove all four 3mm Phillips #0 screws holding in the fan.
    • Remove the tape from the top of the fan
  5. Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: passo 5, imagem 1 %32 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: passo 5, imagem 2 %32 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: passo 5, imagem 3 %32
    • Gently remove the fan from the metal housing.
    • Disconnect the cable with tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
Aaron Austin
Membro desde: 09/22/14
249 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 4-1, Brown Fall 2014 Membro de USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 998
