Ir para o conteúdo principal
Gateway W350I Display Replacement
O que você precisa
  1. Gateway W350I Display Replacement, Battery Access: passo 1, imagem 1 %32
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: passo 2, imagem 1 %32 Gateway W350I Display Replacement, Unlocking the Battery: passo 2, imagem 2 %32 Gateway W350I Display Replacement, Unlocking the Battery: passo 2, imagem 3 %32
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: passo 3, imagem 1 %32 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: passo 3, imagem 2 %32
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
  4. Gateway W350I Display Replacement, Separate Plastic Casing: passo 4, imagem 1 %32 Gateway W350I Display Replacement, Separate Plastic Casing: passo 4, imagem 2 %32
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: passo 5, imagem 1 %32 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: passo 5, imagem 2 %32
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: passo 6, imagem 1 %32
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: passo 7, imagem 1 %32 Gateway W350I Display Replacement, Remove Video Cable: passo 7, imagem 2 %32
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
  8. Gateway W350I Display Replacement: passo 8, imagem 1 %32 Gateway W350I Display Replacement: passo 8, imagem 2 %32
    • Disconnect the camera connector from the circuit board to completely free the screen.
Conclusão
3 outras pessoas executaram este guia.
Samuel Newton
Membro desde: 09/22/14
296 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 4-1, Brown Fall 2014 Membro de USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
Membros da 3
Autoria de 10 guias
Um comentário
It was very easy to follow.
Very friendly guide.
Stephan Williams - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 1,281
