Ir para o conteúdo principal
Gateway Solo 1450 Fan Replacement
O que você precisa
  1. Gateway Solo 1450 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the device is powered down and disconnected from any power sources. Doing this will eliminate any electrical hazards while working on the device.
    • First it is necessary to locate the battery release button. With the laptop orientated so that the screen hinges are facing up the button is located about halfway up the laptop and slightly to the left.
    Pergunte ao FixBot
  2. Gateway Solo 1450 Fan Replacement: passo 2, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 2, imagem 2 %32
    • The next step is to simultaneously push up on the battery release button and to pull out on the battery itself. If this is not done simultaneously then the battery will not budge.
    Pergunte ao FixBot
  3. Gateway Solo 1450 Fan Replacement: passo 3, imagem 1 %32
    • To fully free the battery it is necessary to firmly grasp the battery and give it a firm tug.
    Pergunte ao FixBot
  4. Gateway Solo 1450 Fan Replacement, Keyboard: passo 4, imagem 1 %32 Gateway Solo 1450 Fan Replacement, Keyboard: passo 4, imagem 2 %32
    • Orient the laptop open to see the keyboard. Have the screen tilted all of the way back for easier access as shown.
    Pergunte ao FixBot
  5. Gateway Solo 1450 Fan Replacement: passo 5, imagem 1 %32
    • Above the keyboard, locate the plastic part containing the power button along with various other command buttons. This needs to come off before you can access the keyboard.
    • Use the spudger to assist in this step. Using the spudger, wedge it underneath the component.
    • Once spudger is inserted and pulled far enough, grasp it and firmly, but carefully, pull it out from the left side first
    Pergunte ao FixBot
  6. Gateway Solo 1450 Fan Replacement: passo 6, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 6, imagem 2 %32 Gateway Solo 1450 Fan Replacement: passo 6, imagem 3 %32
    • Once unattached from left side, proceed to right side of component and remove it from clips it is attached to.
    • Once removed from clamps, the part is now removed to provide access to the keyboard.
    Pergunte ao FixBot
  7. Gateway Solo 1450 Fan Replacement: passo 7, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 7, imagem 2 %32
    • The two J0 screws have now become visible. Using the Phillips J0 screwdriver, remove screws. The screws are 5mm long J0 Philips screws.
    Pergunte ao FixBot
  8. Gateway Solo 1450 Fan Replacement: passo 8, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 8, imagem 2 %32 Gateway Solo 1450 Fan Replacement: passo 8, imagem 3 %32
    • Once screws are removed, firmly grasp the top edge of the keyboard and wiggle it slightly while firmly tugging on it. This will release the clips holding it.
    • Once clips become unattached, the keyboard is now out.
    Pergunte ao FixBot
  9. Gateway Solo 1450 Fan Replacement, Screen: passo 9, imagem 1 %32
    • Locate the 2 hinge protectors covering the laptop's hinges.
    • If not already done while you removed the keyboard, unscrew the screws holding the hinge protectors in place.
    Pergunte ao FixBot
  10. Gateway Solo 1450 Fan Replacement: passo 10, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 10, imagem 2 %32 Gateway Solo 1450 Fan Replacement: passo 10, imagem 3 %32
    • Spudger the hinge protectors from the hinges.
    • Remove the hinge protectors from the hinges.
    Pergunte ao FixBot
  11. Gateway Solo 1450 Fan Replacement: passo 11, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 11, imagem 2 %32
    • Locate the 2 pairs of screws that are on each hinge.
    • Unscrew the screws connecting the screen with the hinges.
    Pergunte ao FixBot
  12. Gateway Solo 1450 Fan Replacement: passo 12, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 12, imagem 2 %32
    • Locate where the screen is connected to the laptop's interior.
    • Locate the 2 screws fixing this connection into place.
    • Unscrew the screws holding the connection between the screen and the laptop's interior in place.
    Pergunte ao FixBot
  13. Gateway Solo 1450 Fan Replacement: passo 13, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 13, imagem 2 %32 Gateway Solo 1450 Fan Replacement: passo 13, imagem 3 %32
    • Locate the small piece of plastic above the connection between the screen and the laptop's interior.
    • Carefully insert a spudger into this piece of plastic and separate the connection from the laptop's interior.
    • Remove the connection from the laptop's interior.
    Pergunte ao FixBot
  14. Gateway Solo 1450 Fan Replacement: passo 14, imagem 1 %32
    • Separate the laptop's screen from the rest of the laptop.
    Pergunte ao FixBot
  15. Gateway Solo 1450 Fan Replacement, Fan: passo 15, imagem 1 %32
    • The fan assembly is located in the top left corner of the laptop's interior.
    • Note that there is a metal protective cover on the fan and a metal plate connected to it at the bottom right.
    Pergunte ao FixBot
  16. Gateway Solo 1450 Fan Replacement: passo 16, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 16, imagem 2 %32
    • Locate the 5 points in which the fan's metal protective cover is fixed in place by screws.
    • Unscrew the screws holding the metal protective cover in place.
    Pergunte ao FixBot
  17. Gateway Solo 1450 Fan Replacement: passo 17, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 17, imagem 2 %32
    • Identify the 7 points in which the metal plate connected to the fan's metal protective covering is fixed into place by screws.
    • Unscrew the screws holding the metal plate into place.
    Pergunte ao FixBot
  18. Gateway Solo 1450 Fan Replacement: passo 18, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 18, imagem 2 %32
    • Now that its not fixed to the laptop's interior, remove the entire fan assembly from the laptop.
    Pergunte ao FixBot
  19. Gateway Solo 1450 Fan Replacement: passo 19, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 19, imagem 2 %32
    • Turn over the fan assembly onto its backside so that the fan's metal protective cover is underneath it.
    • Locate the 4 points where the fan is connected to its metal protective cover with screws.
    • Unscrew the screws connecting the fan and its metal protective cover.
    Pergunte ao FixBot
  20. Gateway Solo 1450 Fan Replacement: passo 20, imagem 1 %32 Gateway Solo 1450 Fan Replacement: passo 20, imagem 2 %32
    • Remove the fan from its metal protective cover.
    Pergunte ao FixBot
Conclusão
Zachary Perry
Membro desde: 03/20/18
484 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 51
Ao todo: 481
