Ir para o conteúdo principal
Gateway Solo 1200 Battery Replacement
  1. Gateway Solo 1200 Battery Replacement, Battery: passo 1, imagem 1 %32 Gateway Solo 1200 Battery Replacement, Battery: passo 1, imagem 2 %32 Gateway Solo 1200 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 394
