Ir para o conteúdo principal
Gateway Solo 1200 RAM Replacement
O que você precisa
  1. Gateway Solo 1200  RAM Replacement, Battery: passo 1, imagem 1 %32 Gateway Solo 1200  RAM Replacement, Battery: passo 1, imagem 2 %32 Gateway Solo 1200  RAM Replacement, Battery: passo 1, imagem 3 %32
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200  RAM Replacement, RAM: passo 2, imagem 1 %32
    • Locate the RAM compartment on the underside of the laptop near the center.
  3. Gateway Solo 1200  RAM Replacement: passo 3, imagem 1 %32 Gateway Solo 1200  RAM Replacement: passo 3, imagem 2 %32
    • Open the RAM compartment by unscrewing the 2 mm screw with a Phillips #0 screwdriver.
    • Once unscrewed, lift off the compartment cover.
  4. Gateway Solo 1200  RAM Replacement: passo 4, imagem 1 %32
    • Press the silver retention levers on either side of the RAM away from the center of the RAM.
    • The RAM stick will pop up after the retention levers are released.
  5. Gateway Solo 1200  RAM Replacement: passo 5, imagem 1 %32
    • Pull the RAM stick out of its socket.
Conclusão
5 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 39
Ao todo: 1,031
