Ir para o conteúdo principal
Gateway SA1 Hard Drive Replacement
O que você precisa
  1. Gateway SA1 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
    • Turn the laptop over so the bottom is facing up.
  4. Gateway SA1 Hard Drive Replacement: passo 4, imagem 1 %32 Gateway SA1 Hard Drive Replacement: passo 4, imagem 2 %32
    • Loosen the three Philips cover screws that secure the hard drive.
    • These screws cannot be fully removed from the hard drive cover.
    • Use the spudger to lift and to remove the hard drive cover.
  5. Gateway SA1 Hard Drive Replacement: passo 5, imagem 1 %32 Gateway SA1 Hard Drive Replacement: passo 5, imagem 2 %32
    • Slide the original hard drive to the left and lift it to remove.
    • Insert the new hard drive.
Conclusão
5 outras pessoas executaram este guia.
Diego Carteno
Membro desde: 04/15/10
258 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team 24-20, Regan Spring 2010 Membro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membros
14 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 69
Duração total: 13,571
