Ir para o conteúdo principal
Gateway SA1 Cooling Fan Replacement
O que você precisa
  1. Gateway SA1 Cooling Fan Replacement, Battery: passo 1, imagem 1 %32
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 1 %32 Gateway SA1 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Unscrew the indicated Philips screw.
    • Screw cannot be completely removed from cover.
  4. Gateway SA1 Cooling Fan Replacement: passo 4, imagem 1 %32
    • Use the spudger to pry open the cover.
    • There will be three tabs on each side except for the side with the screw.
  5. Gateway SA1 Cooling Fan Replacement: passo 5, imagem 1 %32 Gateway SA1 Cooling Fan Replacement: passo 5, imagem 2 %32
    • Unscrew the six indicated Philips screws.
    • These screws cannot be completely removed from the cooling fan component.
  6. Gateway SA1 Cooling Fan Replacement: passo 6, imagem 1 %32
    • Unplug the shown cable attaching the cooling fan to the computer.
  7. Gateway SA1 Cooling Fan Replacement: passo 7, imagem 1 %32
    • You are now able to remove the cooling fan.
Conclusão
6 outras pessoas executaram este guia.
Diego Carteno
Membro desde: 04/15/10
258 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team 24-20, Regan Spring 2010 Membro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membros
14 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 13,310
