Ir para o conteúdo principal
Gateway P-6831FX Heatsink Replacement
O que você precisa
  1. Gateway P-6831FX Heatsink Replacement, Heatsink: passo 1, imagem 1 %32 Gateway P-6831FX Heatsink Replacement, Heatsink: passo 1, imagem 2 %32
    • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the Heatsink.
    • Make sure to unplug your laptop charger, as removing the Heatsink while the device is charging may damage the Heatsink and or the charger.
  2. Gateway P-6831FX Heatsink Replacement: passo 2, imagem 1 %32
    • Gently pull the cover away from the device.
  3. Gateway P-6831FX Heatsink Replacement: passo 3, imagem 1 %32 Gateway P-6831FX Heatsink Replacement: passo 3, imagem 2 %32
    • Remove the five Phillips #0 (5mm) screws around the Heatsink.
  4. Gateway P-6831FX Heatsink Replacement: passo 4, imagem 1 %32 Gateway P-6831FX Heatsink Replacement: passo 4, imagem 2 %32
    • Gently pull the Heatsink up and away from the chassis.
Conclusão
Chandler Jardin
Membro desde: 03/19/18
507 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G5, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G5, Peak Spring 2018
UMASSD-PEAK-S18S3G5
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 217
