Ir para o conteúdo principal
Gateway NV59C66u LCD Display Replacement
O que você precisa
  1. Gateway NV59C66u LCD Display Replacement, LCD Display: passo 1, imagem 1 %32 Gateway NV59C66u LCD Display Replacement, LCD Display: passo 1, imagem 2 %32 Gateway NV59C66u LCD Display Replacement, LCD Display: passo 1, imagem 3 %32
    • Remove the black covers over the two screen screws on the bottom corners and unscrew them with a Phillips #0 screwdriver.
  2. Gateway NV59C66u LCD Display Replacement: passo 2, imagem 1 %32 Gateway NV59C66u LCD Display Replacement: passo 2, imagem 2 %32 Gateway NV59C66u LCD Display Replacement: passo 2, imagem 3 %32
    • Now gently remove the screen cover by pulling it apart on all sides with a plastic opening tool.
    • The plastic frame surrounding the screen is very thin and can become brittle with age. Take your time when working the edges to prevent cracking the bezel.
  3. Gateway NV59C66u LCD Display Replacement: passo 3, imagem 1 %32 Gateway NV59C66u LCD Display Replacement: passo 3, imagem 2 %32
    • Carefully pull the latches off with a plastic opening tool.
  4. Gateway NV59C66u LCD Display Replacement: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the screws located in the top corners of the screen
    • make sure to keep all screws nearby and in a safe location so you don't lose them.
  5. Gateway NV59C66u LCD Display Replacement: passo 5, imagem 1 %32 Gateway NV59C66u LCD Display Replacement: passo 5, imagem 2 %32
    • Carefully pop the screen out but do not disconnect it from the cables just yet.
  6. Gateway NV59C66u LCD Display Replacement: passo 6, imagem 1 %32
    • Be sure to support the screen so the cables are not pulled tight. Setting the computer on it's side can help with this.
  7. Gateway NV59C66u LCD Display Replacement: passo 7, imagem 1 %32 Gateway NV59C66u LCD Display Replacement: passo 7, imagem 2 %32 Gateway NV59C66u LCD Display Replacement: passo 7, imagem 3 %32
    • Disconnect the LCD cables on the back of the screen and then remove the screen.
    • set the damaged LCD display to the side and grab the new LCD display.
    • Make sure to support the new LCD screen like you did the damaged one, and slowly reconnect the cables to the new display. Make sure the cables are in the right place.
    • set the new LCD screen in the computer make sure it is secure.
    • Screw in all the screws to hold the screen in place.
    • reset the plastic case to hold the screen in place.
    • Put all latches in the lock position and lightly press the plastic border to the screen to make sure it's in place.
Conclusão
Brian Walker
Membro desde: 10/30/19
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 228
