Introdução
Does your computer die sooner than it did when you bought it? You may need to replace your battery as it might be damaged. This step-by-step guide will show you how to quickly and safely replace your battery for your Gateway NV59C66u laptop.
First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
Locate the Latches below the battery.
Quase terminado!
Conclusão
