Ir para o conteúdo principal
Gateway NV59C66u Battery Replacement
  1. Gateway NV59C66u Battery Replacement, Battery: passo 1, imagem 1 %32
    • First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
    • Locate the Latches below the battery.
  2. Gateway NV59C66u Battery Replacement: passo 2, imagem 1 %32
    • Slide the vertical latch upward, unlocking the battery
  3. Gateway NV59C66u Battery Replacement: passo 3, imagem 1 %32
    • Slide the horizontal latch to the right so you are able to remove the battery from the bottom of your laptop.
  4. Gateway NV59C66u Battery Replacement: passo 4, imagem 1 %32
    • Now the battery is free. Proceed to lift and remove the battery.
    • Place the old batter to the side, as to not get it confused from your new battery you intend to install.
    • Take your new battery and position it into the battery slot you took the old one out of.
    • Make sure latches are in the unlocked position and apply light pressure on the new battery to make sure it is in place.
    • Put latches in lock position and turn laptop over.
    • Turn on your computer.
Conclusão
Jackson Gandee
Membro desde: 10/30/19
521 Reputação
Autoria de 4 guias
Equipe
ETECH Holdings Membro de ETECH Holdings
Community
Membros da 2
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 214
