Ir para o conteúdo principal
Gateway NV57H50u Wireless Network Card Replacement
O que você precisa
  1. Gateway NV57H50u Wireless Network Card Replacement, Battery: passo 1, imagem 1 %32 Gateway NV57H50u Wireless Network Card Replacement, Battery: passo 1, imagem 2 %32 Gateway NV57H50u Wireless Network Card Replacement, Battery: passo 1, imagem 3 %32
    • Push orange locking tab with spudger right, until battery lifts out of place.
    • Laptop should be unplugged from power supply before removal.
  2. Gateway NV57H50u Wireless Network Card Replacement, Rear Cover: passo 2, imagem 1 %32
    • Unscrew the two 7 mm long #0 Phillips screws.
  3. Gateway NV57H50u Wireless Network Card Replacement: passo 3, imagem 1 %32
    • Lift and remove the cover panel via the indentation in the middle of the panel.
  4. Gateway NV57H50u Wireless Network Card Replacement, Wireless Network Card: passo 4, imagem 1 %32
    • Dislocate the white wire by pushing upward away from the network card.
  5. Gateway NV57H50u Wireless Network Card Replacement: passo 5, imagem 1 %32
    • Dislocate the black wire by pushing upward away from the network card.
  6. Gateway NV57H50u Wireless Network Card Replacement: passo 6, imagem 1 %32
    • Unscrew the 3 mm long #0 Phillips head screw.
  7. Gateway NV57H50u Wireless Network Card Replacement: passo 7, imagem 1 %32
    • Pull the card outward to remove.
Conclusão
Aaron Allison
Membro desde: 11/05/18
433 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S1-G1, Baechle Fall 2018 Membro de IUPUI, Team S1-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 387
