Ir para o conteúdo principal
Gateway NV55C49u RAM Replacement
O que você precisa
  1. Gateway NV55C49u RAM Replacement, RAM: passo 1, imagem 1 %32
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u RAM Replacement: passo 2, imagem 1 %32
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u RAM Replacement: passo 3, imagem 1 %32 Gateway NV55C49u RAM Replacement: passo 3, imagem 2 %32
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery.
  4. Gateway NV55C49u RAM Replacement: passo 4, imagem 1 %32
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  5. Gateway NV55C49u RAM Replacement: passo 5, imagem 1 %32 Gateway NV55C49u RAM Replacement: passo 5, imagem 2 %32 Gateway NV55C49u RAM Replacement: passo 5, imagem 3 %32
    • Remove the back cover by placing the plastic opening tool in the indention, and prying upwards.
  6. Gateway NV55C49u RAM Replacement: passo 6, imagem 1 %32 Gateway NV55C49u RAM Replacement: passo 6, imagem 2 %32
    • Hold back the plastic that protects the RAM so you can access the clips underneath.
    • Gently push the holding clips outwards. The RAM will angle itself upwards.
    • Gently remove the RAM from the laptop
    • Make sure not to touch any part of the RAM except the sides.
    • When reassembling, insert the RAM into the connector, and then push it down until the clips lock it into place
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 249
