Ir para o conteúdo principal
Gateway NV55C49u Battery Replacement
O que você precisa
  1. Gateway NV55C49u Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u Battery Replacement: passo 2, imagem 1 %32
    • Switch the battery lock to show a red background with an unlock symbol
  3. Gateway NV55C49u Battery Replacement: passo 3, imagem 1 %32 Gateway NV55C49u Battery Replacement: passo 3, imagem 2 %32
    • Flip the switch with the battery symbol on it.
    • The battery should eject if done correctly.
  4. Gateway NV55C49u Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery by lifting the battery out.
  5. Gateway NV55C49u Battery Replacement: passo 5, imagem 1 %32
    • This battery contains harmful chemicals, so it must be disposed of properly. Please take the old battery to a waste disposal center or recycling center.
    • Tip: in France, you can dispose of the old battery in the battery disposal points that can be found in a lot of supermarkets.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 304
