Ir para o conteúdo principal
Gateway NV53A24u Keyboard Replacement
O que você precisa
  1. Gateway NV53A24u Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Before removing the keyboard, turn off the computer and open it.
  2. Gateway NV53A24u Keyboard Replacement: passo 2, imagem 1 %32 Gateway NV53A24u Keyboard Replacement: passo 2, imagem 2 %32
    • Use a spudger to gently pry out the keyboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
    • There are small metal tabs holding it in place beneath the bezel. Using your tool, you should be able to easily pop the keyboard out.
  3. Gateway NV53A24u Keyboard Replacement: passo 3, imagem 1 %32 Gateway NV53A24u Keyboard Replacement: passo 3, imagem 2 %32
    • Once the keyboard is removed, you may have to remove the connecting ribbon cable, but it easily pulls out.
Conclusão
Uma outra pessoa concluiu este guia.
tannerroan
Membro desde: 10/11/16
333 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-5, Leahy Fall 2016 Membro de USF Tampa, Team 1-5, Leahy Fall 2016
USFT-LEAHY-F16S1G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 498
