Pular para o conteúdo principal
Introdução
The only prerequisite for the WiFi card is the Base Cover.
Peças
Nenhum componente especificado.
  1. Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
    • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
  4. Locate the black and white cables attached to the WiFi card.
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
  5. Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
Conclusão
Ruben
Membro desde: 22-04-2014
277 reputação
2 Guias de autoria
Equipe
Cal Poly, Team 7-24, Regan Spring 2014 Membro de Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Membros
9 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Todo: 950
