Ir para o conteúdo principal
Gateway NV52 Hard Drive Replacement
O que você precisa
  1. Gateway NV52 Hard Drive Replacement, Base Cover: passo 1, imagem 1 %32
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Replacement: passo 2, imagem 1 %32
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Replacement, Hard Drive Compartment: passo 3, imagem 1 %32
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Replacement: passo 4, imagem 1 %32 Gateway NV52 Hard Drive Replacement: passo 4, imagem 2 %32 Gateway NV52 Hard Drive Replacement: passo 4, imagem 3 %32
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
  5. Gateway NV52 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Remove the four identical 1/8" Phillip screws located in every corner of the Hard Drive using the Phillips #0 Screwdriver.
  6. Gateway NV52 Hard Drive Replacement: passo 6, imagem 1 %32
    • Access to the Hard drive by gently sliding the metal cover away from the Hard Drive.
Conclusão
Irma Marin
Membro desde: 04/10/14
608 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-24, Regan Spring 2014 Membro de Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 3,526
