Ir para o conteúdo principal
Gateway NE56R27u Screen Replacement
O que você precisa
  1. Gateway NE56R27u Screen Replacement, Battery: passo 1, imagem 1 %32 Gateway NE56R27u Screen Replacement, Battery: passo 1, imagem 2 %32
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Screen Replacement: passo 2, imagem 1 %32 Gateway NE56R27u Screen Replacement: passo 2, imagem 2 %32
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Screen Replacement, Screen: passo 3, imagem 1 %32 Gateway NE56R27u Screen Replacement, Screen: passo 3, imagem 2 %32 Gateway NE56R27u Screen Replacement, Screen: passo 3, imagem 3 %32
    • Using the spudger, remove the protective caps for the screen to expose the screws.
    • Using the Phillips #000 screwdriver, unscrew the bottom two 1mm screws.
  4. Gateway NE56R27u Screen Replacement: passo 4, imagem 1 %32 Gateway NE56R27u Screen Replacement: passo 4, imagem 2 %32 Gateway NE56R27u Screen Replacement: passo 4, imagem 3 %32
    • Using the opening pick in between the front cover and bezel, gently loosen and lift the plastic bezel from the screen and backing.
  5. Gateway NE56R27u Screen Replacement: passo 5, imagem 1 %32 Gateway NE56R27u Screen Replacement: passo 5, imagem 2 %32
    • Gently lift the frame of the screen from the top to unhook the frame from the base.
    • When reassembling, hook the bottom of the screen to the base of the laptop before snapping into place.
  6. Gateway NE56R27u Screen Replacement: passo 6, imagem 1 %32 Gateway NE56R27u Screen Replacement: passo 6, imagem 2 %32 Gateway NE56R27u Screen Replacement: passo 6, imagem 3 %32
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws in the front corners of the metal frame.
    • Lift the screen slightly to expose the connector board.
  7. Gateway NE56R27u Screen Replacement: passo 7, imagem 1 %32 Gateway NE56R27u Screen Replacement: passo 7, imagem 2 %32
    • Using the spudger, carefully remove the webcam connector from the metal frame.
  8. Gateway NE56R27u Screen Replacement: passo 8, imagem 1 %32 Gateway NE56R27u Screen Replacement: passo 8, imagem 2 %32
    • Peel the tape covering the display cable, releasing the wire from the metal frame.
    • Unplug the display cable from the image processing board on the screen.
  9. Gateway NE56R27u Screen Replacement: passo 9, imagem 1 %32 Gateway NE56R27u Screen Replacement: passo 9, imagem 2 %32
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws from the sides of the metal frame.
    • Remove the screen from the metal frame.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 242
