Introdução
If your motherboard is defective or you are looking to upgrade your Gateway laptop, this guide will show you how to remove your motherboard. Upgrading your motherboard can allow your device to run a faster CPU, faster RAM, faster data transfer, or a better graphics card. Your motherboard is responsible for making all of your device’s components work together, so make sure that all components you may be changing are compatible.
O que você precisa
Flip your laptop over to view the keyboard.
Using the spudger, push in the ten tabs at the edges of the keyboard.
Using a Phillips #000 driver, remove the three silver 0.79mm screws located on the back edge of the battery compartment.
Using the hook end of a halberd spudger, gently pry up the black and white wires from the wireless card.
Uma outra pessoa concluiu este guia.
