Ir para o conteúdo principal
Gateway NE56R27u Keyboard Replacement
O que você precisa
  1. Gateway NE56R27u Keyboard Replacement, Battery: passo 1, imagem 1 %32 Gateway NE56R27u Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Keyboard Replacement: passo 2, imagem 1 %32 Gateway NE56R27u Keyboard Replacement: passo 2, imagem 2 %32
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Keyboard Replacement, Hard Drive: passo 3, imagem 1 %32 Gateway NE56R27u Keyboard Replacement, Hard Drive: passo 3, imagem 2 %32 Gateway NE56R27u Keyboard Replacement, Hard Drive: passo 3, imagem 3 %32
    • Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
  4. Gateway NE56R27u Keyboard Replacement: passo 4, imagem 1 %32 Gateway NE56R27u Keyboard Replacement: passo 4, imagem 2 %32
    • Use the opening tool to gently pry open the compartment covering.
  5. Gateway NE56R27u Keyboard Replacement: passo 5, imagem 1 %32 Gateway NE56R27u Keyboard Replacement: passo 5, imagem 2 %32 Gateway NE56R27u Keyboard Replacement: passo 5, imagem 3 %32
    • Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
    • Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
    • The hard drive plugs into the port on the left within the compartment. Be sure to gently remove the hard drive without damaging the port.
  6. Gateway NE56R27u Keyboard Replacement: passo 6, imagem 1 %32 Gateway NE56R27u Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
  7. Gateway NE56R27u Keyboard Replacement, Keyboard: passo 7, imagem 1 %32 Gateway NE56R27u Keyboard Replacement, Keyboard: passo 7, imagem 2 %32
    • Flip your laptop over to view the keyboard.
    • Using the spudger, push in the ten tabs at the edges of the keyboard.
  8. Gateway NE56R27u Keyboard Replacement: passo 8, imagem 1 %32 Gateway NE56R27u Keyboard Replacement: passo 8, imagem 2 %32
    • Using the opening pick, lift the edges of the keyboard.
    • Repeat around the edges of the device.
    • Lift up the keyboard to expose the cables underneath.
  9. Gateway NE56R27u Keyboard Replacement: passo 9, imagem 1 %32 Gateway NE56R27u Keyboard Replacement: passo 9, imagem 2 %32 Gateway NE56R27u Keyboard Replacement: passo 9, imagem 3 %32
    • Release the clamp holding the mini-DIN cord by lifting the two black tabs on either side.
    • Gently pull the mini-DIN cord out of the clamp.
    • Remove the keyboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 574
