Introdução
This guide teaches you how to replace the hard drive in a Gateway NE series laptop.
O que você precisa
Remove the two Philips screws securing the hard drive cover to the base.
Pry the hard drive cover off with a spudger.
With the laptop's battery side facing you, pull the hard drive caddy's tab to the right.
2 comentários
Does replacement of harddrive effect memory?
