Ir para o conteúdo principal
Gateway NE52214U Motherboard Replacement
O que você precisa
  1. Gateway NE52214U Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Gateway NE52214U Motherboard Replacement: passo 2, imagem 1 %32 Gateway NE52214U Motherboard Replacement: passo 2, imagem 2 %32
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. Gateway NE52214U Motherboard Replacement, Upper Case: passo 3, imagem 1 %32 Gateway NE52214U Motherboard Replacement, Upper Case: passo 3, imagem 2 %32
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Gateway NE52214U Motherboard Replacement: passo 4, imagem 1 %32
    • Flip over the laptop and open it so the screen is facing you.
  5. Gateway NE52214U Motherboard Replacement: passo 5, imagem 1 %32
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
  6. Gateway NE52214U Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
  7. Gateway NE52214U Motherboard Replacement: passo 7, imagem 1 %32 Gateway NE52214U Motherboard Replacement: passo 7, imagem 2 %32
    • Gently lift and remove the motherboard off of device.
    • This will also remove the fan from the device but it will remain attached to the motherboard.
Conclusão
Kelsey Rodrigues
Membro desde: 10/23/18
495 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S1-G1, Simcock Fall 2018 Membro de UMass Dartmouth, Team S1-G1, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 343
